ZenBook Duo 2026 Review
Intel sneaks a lil' Celestial into their Mobile 300-Series.
in Tablet & Laptops, Reviews
11. Closer Look at Asus ZenBook Duo P.6
  • 2. Closer Look at Panther Lake p.1 (Cougar Cove)
  • 3. Closer Look at Panther Lake p.2 (Cougar Cove Cont’d)
  • 4. Closer Look at Panther Lake p.3 (NPU/AI/IMC)
  • 5. Closer Look at Panther Lake p.4 (DarkMont & BattleMage)
  • 6. Closer Look at Asus ZenBook Duo P.1
  • 7. Closer Look at Asus ZenBook Duo P.2
  • 8. Closer Look at Asus ZenBook Duo P.3
  • 9. Closer Look at Asus ZenBook Duo P.4
  • 10. Closer Look at Asus ZenBook Duo P.5
  • 11. Closer Look at Asus ZenBook Duo P.6
  • 12. Adobe Performance
  • 13. Blender & CineBench Results
  • 14. DaVinci & OpenSCAD
  • 15. Handbrake 265 & PSY-Handbrake AV1
  • 16. SolidWorks & PCMark
  • 17. winRAR & x264 HD
  • 18. Borderlands 3 & CyperPunk 2077
  • 19. Closing Thoughts
ZenBook Duo 2026 Review 48
The last three features worth mention is the integrated kickstand, the bezel, and the hinge for the screens. Not only does this kickstand allow you to safely and securely tilt the laptop so that both screens are usable in a virtual Big Boi screen, but it is now made from Ceraluminum. Meaning you will have to work at breaking it. Asus states the stand hinge is good for at least 40K cycles and can handle 15KG of weight. Which is a w very nice, and timely, upgrade to say the least over the last gen.
ZenBook Duo 2026 Review 49
The bezels. Thanks to trimming of the fat, there is now only ~4.3mm gap around the sides of the screens (down from ~6mm), and a mere ~9mm gap between the two when fully folded open… as the math gets tricky when dealing with angles (down from ~25mm). Giving this Duo a ~93% screen to body ratio vs. 83’ish percent of the last gen. Meaning that when in presentation mode, gaming mode, or dual screen work mod,e you get a much cleaner presentation with less black bar distractions.
ZenBook Duo 2026 Review 50
The reason for such a narrow gap between the two screens, when compared to the last generation, is the fact that ASUS has upgraded the hinge. In the previous 2024 edition, the design was basically using a slightly modify standard hinge. Which not only bulked up the gap but also kept you from fully flattening it out into a 180-degree configuration. With the new model, Asus has gone to a ‘hideaway’ hinge that pivots and moves as the screens are opened/closed. This narrows the gap but, more importantly, gives you 180-degree opening abilities.
ZenBook Duo 2026 Review 51
In fact its more like 183 as you can tilt it beyond flat and actually give a slight negative tilt to the second screen. Why would anyone do that? Simple. You can now use the “main” screen in ‘flip’ mode and use it as a good presentation display for anyone sitting across from you. As such, we can see many a salesman (or just student) using it for presentations. Even lawyers could use it as it is a touch screen and a digital signature backstopped by video evidence (as the camera is on the top screen and is typically legally binding in and out of court depositions). We can even see small teams at booths (say a Lost Wages event, or even just at a local farmers market) using it as rough n ready Point of Sales device. Though personally, we can see installing a certain “blue” emulator and running Android games on it… or another emulator and running ‘retro’ games on it. So this hinge really does expand the possibilities. Color us impressed… as we always like to see good engineering in action.
ZenBook Duo 2026 Review 52
Mix in a very good, and relatively compact 100w power adapter, and as you can see, the new 2026 edition of the ZenBook Duo has a lot of good, and sometimes great, upgrades over its predecessor. It’s just not perfect, and certain cost-cutting measures are blatantly obvious because of those upgrades. As such, it is a quirky ultraportable laptop that actually makes a good case for why dual-screen laptops should be more prevalent… as now want to see the 388H on a dual 4K 15-inch model… with DIMM slots and TB5 ports.
Page 11 of 19
Tags: ASUS Zenbook Duo 2026Battlemage iGPUCore Ultra Series 3Dual-Screen LaptopIntel 18A NodeIntel Arc B390Intel Core Ultra 9 388HIntel Panther LakeUX8407 ReviewXe3 Graphics
Intel Unveils 15th Gen Core Ultra Series CPUs
October 10, 2024
MSI GH70 GAMING HEADSET
July 13, 2017
