Silicon Power XS70 1TB Review
Silicon Power 1TB XS70 - Works with Playstation 5, Nvme PCIe Gen4 M.2 2280 Internal Gaming SSD...
Silicon Power 1TB XS70 - Works with Playstation 5, Nvme PCIe Gen4 M.2 2280 Internal Gaming SSD R/W Up to 7,300/6,000 MB/s (SP01KGBP44XS7005)
9. Boot time and Data Transfer
  • 1. Cooling, Performance and Value? Yes Please!
  • 5. Sequential Performance
  • 6. ATTO Disk Benchmark
  • 8. IOMeter
  • 10. Adobe & VMWare
  • 11. Game Load Time
  • 13. Seagate FireCuda 520: Score Card and Summary
  • 14. Closing Statement
System Boot Time
Silicon Power XS70 1TB Review 35
Real World Data Transfers
Silicon Power XS70 1TB Review 36
Silicon Power XS70 1TB Review 37
  • 8. IOMeter
Page 9 of 14
Tags: 1tbGEN4NVMESilicon Power XS70 1TBstorage
