Silicon Power US70 1TB Review
Silicon Power 1TB UD90 NVMe 4.0 Gen4 PCIe M.2 SSD R/W up to 5,000/4,800 MB/s (SP01KGBP44UD9005)
Silicon Power 1TB NVMe M.2 PCIe Gen3x4 2280 TLC R/W up to 3,400/3,000MB/s SSD (SU001TBP34A80M28AB)
9. Boot time and Data Transfer
  • 1. A budget friendly, high performance PCIe 4.0 SSD
  • 5. Sequential Performance
  • 6. ATTO Disk Benchmark
  • 8. IOMeter
  • 10. Adobe & VMWare
  • 11. Game Load Time
  • 13. Score Card and Summary
  • 14. Closing Statement
System Boot Time
Silicon Power US70 1TB Review 25
Real World Data Transfers
No matter how good a synthetic benchmark like IOMeter is, it cannot really tell you how your hard drive will perform in “real world” situations. To this end we will be running timed data transfers to give you a general idea of how its performance relates to real life use. To help replicate worse case scenarios we will transfer a 100.00GB contiguous file, then a folder containing 1200 subfolders with a total 36,000 files varying in length from 200mb to 100kb (30.00 GB total).
Silicon Power US70 1TB Review 26
Silicon Power US70 1TB Review 27
  • 8. IOMeter
Page 9 of 14
Tags: Silicon PowerSilicon Power US70 1TBUS70
