Silicon Power US70 1TB Review
Silicon Power 1TB UD90 NVMe 4.0 Gen4 PCIe M.2 SSD R/W up to 5,000/4,800 MB/s (SP01KGBP44UD9005)
Silicon Power 1TB NVMe M.2 PCIe Gen3x4 2280 TLC R/W up to 3,400/3,000MB/s SSD (SU001TBP34A80M28AB)
5. Sequential Performance
  • 1. A budget friendly, high performance PCIe 4.0 SSD
  • 5. Sequential Performance
  • 6. ATTO Disk Benchmark
  • 8. IOMeter
  • 10. Adobe & VMWare
  • 11. Game Load Time
  • 13. Score Card and Summary
  • 14. Closing Statement
Read Bandwidth
Silicon Power US70 1TB Review 16
Write Performance
Silicon Power US70 1TB Review 17
  • 8. IOMeter
Page 5 of 14
Tags: Silicon PowerSilicon Power US70 1TBUS70
