in Reviews, Recent, Storage
Seagate IronWolf Pro 18TB NAS Internal Hard Drive HDD – 3.5 Inch SATA 6Gb/s 7200 RPM 256MB Cache...
Seagate IronWolf Pro 18TB NAS Internal Hard Drive HDD – 3.5 Inch SATA 6Gb/s 7200 RPM 256MB Cache for RAID Network Attached Storage, Data Recovery Service – Frustration Free Packaging (ST18000NE000)
Seagate IronWolf Pro 18TB NAS Internal Desktop Hard Drive, SATA 6GB/s, 7200 RPM
Seagate Exos X20 20TB Enterprise HDD - CMR 3.5 Inch Hyperscale SATA 6Gb/s, 7200 RPM, 512e and 4Kn...
Seagate Exos X20 20TB Enterprise HDD - CMR 3.5 Inch Hyperscale SATA 6Gb/s, 7200 RPM, 512e and 4Kn FastFormat, Low Latency with Enhanced Caching - ST20000NM007D (Renewed)
4. Multi-Tier Caching Technology
  • 1. The Evolution of a series continues
  • 5. Closer Look
Seagate IronWolf Pro 18TB Review 11
Multi-Tier Caching technology (MTC for short) is the umbrella term that Seagate has come up with to explain all the various enhancements they have crafted for hard disk drives they obtained from the SandForce IP when they purchased this division from LSI a few years back. Yes, it has taken Seagate that long to modify and tweak as hard drive and solid-state storage is radically different. Beyond taking their time to get it right MTC is a combination of algorithms and other low-level enhancements that allow for a radically different approach to a hard drive’s controller and its caching. As time goes by, so too do the MTC algorithms change/improve. Seagate is constantly refining them and every generation should bring some improvement(s) to the table… whether you notice it or not.
Seagate IronWolf Pro 18TB Review 12
MTC on the other hand is best considered a marriage of Seagate’s previous Solid-State Hybrid Drives with their Hard-Disk Drive lines… just without the need of expensive – and relatively short lived – NAND. Basically, just like a SSHD (sans downsides of cost and lifespan) MTC allows the ‘secretary’ the luxury of making multiple branch predictions and storing all these possibilities in their on hand ‘filing cabinet’. Not only does this increase the hit ratio it allows the ‘secretary’ the luxury of actually being able to properly use the entire filing cabinet, but making the filing cabinet even larger also makes the secretary even more efficient. This is why, unlike previous predictive caching algorithms, using a 256MB cache buffer actually makes sense – and going even bigger would potentially net even better results.
Seagate IronWolf Pro 18TB Review 13
That obviously is not possible with hard drive storage, so after Seagate identified these areas they then spent the time and effort classifying how these areas are used in the real world. For instance, a HDD placed into a NAS is going to have more ‘large file’ random read/write IO requests than say a HDD in a home users system; whereas an OS or even secondary storage drive will need small(er) file sequential and random performance boosted. With this information now available to Seagate engineer’s they can with very little effort tweak how much priority each of these underlying algorithms need, hardcode that into the firmware of a given model… and go from there. Yes, this boosting of certain algorithms (or to be more precise giving them higher processor cycle and cache storage priority) means it comes at the expense of other areas, but tailor-made performance means as long as you choose the right model… the ‘real world’ performance for your needs will be higher than ever before.
Seagate IronWolf Pro 18TB Review 14
This is also why when you purchase a Seagate Guardian series drive with retail packaging you will notice a different MTC logo on the front of the box and the drive. For example, the Seagate BarraCuda models come with the word ‘compute’ in bold prominence. Whereas on an IronWolf it will be “NAS”. Once you understand what the ‘code name’ or branding means, picking the proper model becomes a lot more straightforward than trying to remember a color – like Western Digital does. This is an extremely elegant solution to conveying a rather complex subject in such a manner that even a novice buyer will almost instantly ‘get it’.
  • 5. Closer Look
Page 4 of 16
Tags: IronWolf Pro 18TBSeagateSeagate IronWolfSeagate IronWolf ProSeagate IronWolf Pro 18TB
Crucial X6 2TB External SSD Review
