Seagate IronWolf Pro 16TB Review
Same great performance, now less (budget) filling
in Storage, Reviews
Seagate IronWolf Pro 16TB NAS – 3.5 Inch SATA 6GB/S 7200 RPM 256MB Cache for Raid Network...
Seagate IronWolf Pro 16TB NAS – 3.5 Inch SATA 6GB/S 7200 RPM 256MB Cache for Raid Network Attached Storage, Data Recovery Rescue Service (ST16000NE000) (Renewed) Internal Hard Drive HDD
Seagate IronWolf Pro 16TB NAS Internal Hard Drive HDD – CMR 3.5 Inch SATA 6GB/S 7200 RPM 256MB...
Seagate IronWolf Pro 16TB NAS Internal Hard Drive HDD – CMR 3.5 Inch SATA 6GB/S 7200 RPM 256MB Cache for Raid Network Attached Storage, Data Recovery Rescue Service
Seagate IronWolf Pro ST16000NE000 16 TB Hard Drive - 3.5" Internal - SATA (SATA/600) (Renewed)
3. Seagate IronWolf pro 16TB: Guardian Series Primer
  • 3. Seagate IronWolf pro 16TB: Guardian Series Primer
  • 5. Closer Look
Seagate IronWolf Pro 16TB Review 7
Before we begin a bit of background information and explanation is in order. Seagate has indeed gone back to the drawing board to create a new lineup meant to stem the incursion of Solid State Drives into their home turf. The end result of all their hard work, and countless man-hours of R’n’D, is the multi-model ‘umbrella’ series they have called the Guardian Series. The Guardian Series is not just one storage model and rather is a multitude of models, each intended for different markets. What they all have in common however is their Multi-Tier Caching Technology (MTC), which has tuned for different scenarios and the underlying technology does differ somewhat.
Seagate IronWolf Pro 16TB Review 8
The SkyHawk is what Seagate calls their next generation home and SOHO orientated surveillance HDD series. These hard drives are tuned for low power consumption, low noise, and low IOPS scenarios – as shear performance is not really needed for recording and playback of video. What this means is instead of 7200rpm platters using Perpendicular Magnetic Recording (PMR) / conventional magnetic recording technology it is a 5900rpm Shingle Magnetic Recording (SMR) based system with the MTC tuned for ‘surveillance’ storage tasks. In other words, this is Seagate’s answer to Western Digital’s ‘Purple’ series. Put another way if you have never used a Purple hard drive, or own a TCP/IP based surveillance system, the SkyHawk will probably not be an optimal choice if you prioritize performance over everything else.
Seagate IronWolf Pro 16TB Review 9
The IronWolf series is Seagate’s new Network Attached storage option. Both the standard and Pro models are PMR/CMR (both mean the same thing) based with 7200rpm spindle speeds. Both have the MTC tuned for quirky rigors of being placed in a NAS appliance or RAID configuration. One of these quirks is having Time-Limited Error Recovery turned on so that the hard drive will not spend much time fixing low level errors. Instead it will tell the storage controller to handle it via parity stripe ECC. This reduces latency spikes and is perfect for RAID based storage performance. Outside of RAID though it is a less than optimal choice, but the increased vibration resistance and other features that allow for long term use in near-line and on-line storage scenarios actually does cross over nicely in to HTPC territory where space is usually at a premium and HDDS are stacked in close proximity to one another.
Seagate IronWolf Pro 16TB Review 10
This brings us to the yeoman model of the hard disk drive portion of the Guardian series: the Seagate BarraCuda models. The standard is a 5900rpm PMR/CMR based model that is helium filled and has had the MTC tuned for the needs of the home consumer. The Pro variant ups the performance via 7200rpm platter speed and some slight adjustments to the MTC so as to be able to both excel at being a ‘C’ / ‘Operating System’ drive or ‘D’ / ‘secondary’ storage option for consumers.
Seagate IronWolf Pro 16TB Review 11
The last round in the initial Guardian salvo is the FireCuda. This is a solid-state and hard-disk drive ‘hybrid’ model that has been tailor made for home consumers and systems builders alike. Thanks to its powerful controller, good NAND, and Seagate’s IP in both HDD and SSD arenas it represents Seagate getting back into the SSHD corner of the marketplace with all the flair and style they are known for.
  • 5. Closer Look
Page 3 of 16
Tags: IronwolfIronWolf ReviewSeagateSeagate IronWolf Pro 16TB
Seagate 1TB Expansion Desktop Review
