Home Video Reviews
Reeven E12 RGB Review
in Video Reviews, Accessories, Recent, Reviews, Unboxing
HEKEE E12 LED Candelabra Light Bulbs, Color Changing Candle, 40W Incandescent Equivalent, 450...
HEKEE E12 LED Candelabra Light Bulbs, Color Changing Candle, 40W Incandescent Equivalent, 450 Lumen, RGB + 2700K Warm White, 5Watt, 12 Colors, 2 Modes, Timer, Remote Control (4 Pack)
LUMIMAN Candelabra Smart Bulb E12 LED Smart Light Bulbs WiFi RGB Color Changing Smart Lights That...
LUMIMAN Candelabra Smart Bulb E12 LED Smart Light Bulbs WiFi RGB Color Changing Smart Lights That Work with Alexa Google Home Music Sync Tunable White 5W 400lm No Hub Required 1 Pack
Smart Candelabra LED Bulbs, 60 Watt Equivalent, 6W 500lm, E12 LED Bulbs Work with Alexa and...
Smart Candelabra LED Bulbs, 60 Watt Equivalent, 6W 500lm, E12 LED Bulbs Work with Alexa and Google Home, 2700-6500K+RGB, APP Control, No Hub Required, Timer, Group Control, 2.4GHz WiFi Only, 4PCS
5. Testing Methodology
  • 1. Smaller Cooler, Massive Value
  • 4. Installation Issues
  • 7. Intel System
    Reeven E12 RGB Review 28
    Reeven E12 RGB Review 29
    AMD System:
    Reeven E12 RGB Review 30
    Reeven E12 RGB Review 31
  • 8. Performance Results (Maximum Fans configuration)
  • 9. Intel
  • 10. Reeven E12 RGB Review 32
  • 11. AMD
  • 12. Reeven E12 RGB Review 33
  • 13. Performance Results (Noise)
While there are many, many ways of properly and efficiently testing CPU cooling solutions not every method will offer useful information for all potential buyers. Some consumers care more about noise than shear performance (aka ‘Silent PC’ enthusiasts). Others only care about performance and do not mind in the least if the cooler is as loud as a jet plane. Others still want to know how flexible a cooler is and how effective it will be at moderate – not silent – noise levels. Most though fall somewhere in the middle and want a good all-round design. Further complicating things is results on AMD systems do not necessarily translate to Intel based testbeds (and vice versa) as the CPU is a different size and will come in direct contact with more/less of the CPU cooling solution’s heatsink.
To this end we are not just going to present you our readers with an overly simplified result and call it good enough. Instead we are going to do our best to provide you with as much data as possible so that you can make an informed decision based on what you consider to be important.
This different approach starts with testing on two testbeds and not just one. The first is an AMD AM4 Ryzen 1700X based system that is a good representation of what AMD users will experience. For Intel we have opted for a i7 8700K based system. Both are tested at stock and a moderately stressful overlock.
The included results are the average for 20 minutes of stress testing using Aida64 and its built in stress testing with logging feature enabled (as found under File / Preferences / Hardware Monitoring / Logging). In cases where ‘maximum’ fan speed falls between two chart points we will take a rounding up approach and place the max numbers under the higher fan speed point.
To round out our testing we have also included fan noise using stock number of fans included in the box, and at all successful rotational speed points. These results are taken using a professionally calibrated and NIST certified DT-805 sound meter that is placed 24 inches away from the cooler. We then spin up or down the fan on the cooling solution while the (Intel) CPU is idling.
Intel Testbed:
Processor: Intel 8700K
Memory: Ballistix Sport AR DDR4-3000
Motherboard: ASUS TUF-Z370 Pro Gaming
Cooling: various
Power Supply: Corsair AX860i
Monitor: Dell U2714H
OS: Windows 10 Professional
AMD Testbed:
Processor: AMD Ryzen 1700X
Motherboard: ASUS ROG STRIX Z370-E Gaming
Cooling: various
Reeven E12 RGB Review 27
  • 7. Intel System
    AMD System:
  • 9. Intel
  • 11. AMD
Page 5 of 15
Tags: AMDBest Silent coolerCoolingCPU CoolerIntelMugen 5Mugen 5 ReviewNinja 5NoctuaReevenReeven E12RGBScytheSilent Cooler
EVGA CLC 240 Review
EVGA CLC 240 Review
Biostar Releases GK3 Sub $50 Mechanical Keyboard
November 22, 2016
March 12, 2019
