PNY GeForce GTX 970 XLR8 4GB
in GPU, Reviews
PNY XLR8 GeForce GTX 460 1024MB GDDR5 PCI-Express 2.0 DVI-I+DVI-I+HDMI mini Overclocked Graphics...
PNY XLR8 GeForce GTX 460 1024MB GDDR5 PCI-Express 2.0 DVI-I+DVI-I+HDMI mini Overclocked Graphics Card VCGGTX4601XPB-OC
PNY XLR8 GeForce GTX 580 1536MB GDDR5 PCI-Express 2.0 DVI-I+DVI-I+HDMI mini Graphics Card...
PNY XLR8 GeForce GTX 580 1536MB GDDR5 PCI-Express 2.0 DVI-I+DVI-I+HDMI mini Graphics Card VCGGTX580XPB
PNY GeForce GTX 1650 4GB GDDR6 Dual Fan Graphics Card
14. PNY GeForce GTX 970 XLR8 4GB – Temp, Noise and Power
  • 1. PNY GeForce GTX 970 XLR8 4GB – Intro
  • 2. PNY GeForce GTX 970 XLR8 4GB Testing Methodology
  • 3. PNY GeForce GTX 970 XLR8 4GB – Synthetic Explained
  • 4. PNY GeForce GTX 970 XLR8 4GB – Sleeping Dogs
  • 5. PNY GeForce GTX 970 XLR8 4GB – Metro: Last Light
  • 6. PNY GeForce GTX 970 XLR8 4GB – BioShock Infinite
  • 7. PNY GeForce GTX 970 XLR8 4GB – Tomb Raider
  • 8. PNY GeForce GTX 970 XLR8 4GB – Batman Arkham Origins
  • 9. PNY GeForce GTX 970 XLR8 4GB – Real World In-Game Explained
  • 10. PNY GeForce GTX 970 XLR8 4GB – Battlefield 4
  • 11. PNY GeForce GTX 970 XLR8 4GB – Assassins Creed: Black Flag
  • 12. PNY GeForce GTX 970 XLR8 4GB – CoD: Ghosts
  • 13. PNY GeForce GTX 970 XLR8 4GB – Crysis 3
  • 14. PNY GeForce GTX 970 XLR8 4GB – Temp, Noise and Power
  • 15. PNY GeForce GTX 970 XLR8 4GB – Overclocking
  • 16. PNY GeForce GTX 970 XLR8 4GB – Summary and TL;DR
  • 17. PNY GeForce GTX 970 XLR8 4GB – Score Card
  • 18. PNY GeForce GTX 970 XLR8 4GB – Closing Statement
Temperature, Noise, and Power Analysis
temp
Regardless of how less than perfect the stock cooler design is the fact of the matter is the GM204 core at stock levels is rather cool running. As such even a mediocre blower fan and small heatsink is more than enough to keep this core running within specifications. Of course we do wonder how large an impact on overclocking this heatsink and fan combination will have. We do have a sneaking suspicion that it and not the GM204 core will be the major limiting factor of overclocking. Hopefully this cooler has more performance than we think it does.
Sound Level Test Results
For Idle tests, we let the system idle at the Windows 7 desktop for 25 minutes and recorded the peak dB.
noise
We must admit that we thought this card was going to do worse than it did. Thankfully the GM204 is a cool running design and while the heatsink and blower combination PNY has opted for is rather less than optimal it still manages to keep noise levels within the realm of reasonable. We just wish that PNY had not gone down the blower route and instead had used one of their excellent custom down-draft style coolers on this bad boy.
System Power Consumption
power
Based on the 750Ti results, and low TDP of this card, we knew that Maxwell was a very power efficient GPU. What was not expected was exactly how big a power miser this bad boy really is. Take a close look at that cart and you will see a massive reduction in power consumption in just one generation. That really goes to show how big a paradigm shift the GM204 core is. The very fact that it not only requires less power but down right annihilates the previous generation 770 is just underscores how big a deal this new Maxwell core really is.
Page 14 of 18
Tags: Gaming Graphics cardGTX 970GTX 970 XLR8PNY GeForce GTX 970 XLR8 4GBXLR8
MiniTool Partition Wizard Pro
