MSI MPG CoreLiquid P13 360 Review
When Innovation Meets Elegance
MSI MPG CORELIQUID P13 360 - AIO ARGB CPU Liquid Cooler - 360mm Radiator - LGA 1851 / AM5 Ready -...
MSI MPG CORELIQUID P13 360 - AIO ARGB CPU Liquid Cooler - 360mm Radiator - LGA 1851 / AM5 Ready - IPS 2.1" LCD Screen - Triple 120mm ARGB PWM Fans - Uni Bracket - Black
MSI MPG CORELIQUID P13 360 White - AIO ARGB CPU Liquid Cooler - 360mm Radiator - LGA 1851 / AM5...
MSI MPG CORELIQUID P13 360 White - AIO ARGB CPU Liquid Cooler - 360mm Radiator - LGA 1851 / AM5 Ready - IPS 2.1" LCD Screen - Triple 120mm ARGB PWM Fans - Uni Bracket - White
7. Testing Methodology
  • 6. Installation & Quirks
  • 8. Performance Results
  • 10. Score Card and Summary
  • 11. Closing Statement
While there are many, many ways of properly and efficiently testing CPU cooling solutions not every method will offer useful information for all potential buyers. Some consumers care more about noise than sheer performance (aka ‘Silent PC’ enthusiasts). Others only care about performance and do not mind in the least if the cooler is as loud as a jet plane. Others still want to know how flexible a cooler is and how effective it will be at moderate – not silent – noise levels. Most though, fall somewhere in the middle and want a good all-round design. Further complicating things is that results on consumer Intel systems do not necessarily translate to AMD CPU-based testbeds (and vice versa)… as the CPU is a different size and will come in direct contact with more/less of the CPU cooling solution’s heatsink.
To this end, we are not just going to present you our readers with an overly simplified result and call it good enough. Instead, we are going to do our best to provide you with as much data as possible so that you can make an informed decision based on what you consider to be important.
This different approach starts with testing on two testbeds and not just one. The first is an Intel 13th-generation Core i9-13900K CPU. This CPU’s thermal characteristics make it a good representation of for what most upper-mainstream users will experience. For AMD fans, we have an older Zen 3 Ryzen 9 5950X processor. A processor that just does not like to run cool.
Further helping to give as clear a picture of a given cooler’s real-world performance, we will also be testing a test sample with the stock number of fans (i.e. whatever number is included in the box), and (when possible) the maximum number of fans. For most air-based coolers, this means one fan for stock, and two to three for maximum results; whereas with water-based, stock could be one to three, and three to six for maximum.
Since not all fans are made the same, we will also be testing the review sample at various fans speeds. While many can go below 800rpms few will not spin at below this level and fewer still do so while keeping temperatures in check. This is why we have chosen 800RPM as the minimum fan speed cut-off, and from then on we increase the rotational speed in 200 to 250 RPM increments until the fan is running at ‘full speed’. This can vary from 1200 to over 3000… and will help highlight how much – or little – extra performance the increase in rotational speed brings to the table. Our personal cut off for CPU temperature is 90 degrees, but to give as full a picture as possible we have opted (when possible) for 95 C as the cutoff and as such once 95-degree temperature results are reached no further results below that fan speed will be included.
Intel Testbed:
Memory: Crucial Pro DDR5-5600
Cooling: Various
Power Supply: Corsair AX860i
Monitor: Dell U2714H
OS: Windows 11 Professional
AMD Testbed:
Processor: AMD Ryzen 9 5950X
Cooling: Various
Page 7 of 11
Previous 1234567891011 Next
Tags: 360mm radiatorAIO coolerAll in oneCoreLiquid P13CPU Coolereasy installationHigh PerformanceIntel compatibilityLGA1700Liquid CoolingMPG CORELIQUID P13MSIquiet operationUni bracket
Intel Panther Lake
Intel Panther Lake
