MSI GeForce RTX 5060 Ti 16G GAMING OC Review
An Actually Good Argument For Buying a x60Ti Class Card?!
in Reviews, GPU
16. Temperature, Noise, and Power Analysis
  • 2. Packaging & Accessories
  • 6. Overclocking
  • 7. AC: Mirage, Cyberpunk 2077
  • 8. Battlefield 5, CoD: MWII
  • 9. Crysis 3, Far Cry 6
  • 10. GTA V, Hitman 3
  • 11. Metro Exodus, S.T.R.
  • 12. The Division 2, Watch Dogs: Legion, Witcher 3
  • 13. Ray Tracing Performance
  • 14. Adobe PP & Blender
  • 15. DaVinci, Handbrake, Topaz AI
  • 17. Closing Thoughts
MSI GeForce RTX 5060 Ti 16G GAMING OC Review 80
Sound Level Test Results
MSI GeForce RTX 5060 Ti 16G GAMING OC Review 81
System Power Consumption
To obtain accurate results we have connected the system to a Power Angle power meter that has in turn been attached to a 1500watt UPS. This ensures only 120volt power is supplied to the PSU and removes any variances that could potential crop up because of brownouts and power spikes.
MSI GeForce RTX 5060 Ti 16G GAMING OC Review 82
  • 6. Overclocking
Page 16 of 17
Tags: 1080p gaming1440p gaming4K GamingBest Value GPUBudget GPUDLSSgaming hardwaregaming PCGPU ReviewGraphics CardMSI Graphics CardMSI RTX 5060TiNvidiaPC buildPC gamingRTX 5060TiRTX 60 Series
MSI MPG A1000GS Review
