Lexar Pro 1066x (CF)
Lexar Professional 1066x 32GB VPG-65 CompactFlash card (LCF32GCRBNA1066)
Lexar Professional 128GB 1066x Speed 160MB/s CompactFlash Memory Card
Lexar Professional 1066x 128GB CompactFlash Card, Up to 160MB/s Read, for Professional...
Lexar Professional 1066x 128GB CompactFlash Card, Up to 160MB/s Read, for Professional Photographer, Videographer, Enthusiast (LCF128CRBNA1066)
7. Lexar Pro 1066x (CF) – Synthetic Test Results
  • 1. Lexar Pro 1066x (CF) – Introduction
  • 2. Lexar Pro 1066x (CF) – Specifications and Features
  • 3. Lexar Pro 1066x (CF) – What is CF and Why Should You Care
  • 4. Lexar Pro 1066x (CF) – Closer Look
  • 5. Lexar Pro 1066x (CF) – Image Rescue 5
  • 6. Lexar Pro 1066x (CF) – Testing Methodology
  • 7. Lexar Pro 1066x (CF) – Synthetic Test Results
  • 8. Lexar Pro 1066x (CF) – Real World Test Results
  • 9. Lexar Pro 1066x (CF) – Score Card, Performance Summary & TL;DR
  • 10. Lexar Pro 1066x (CF) – Closing Statement
For synthetic tests we have used a brand new Lexar WorkFlow USB 3.0 CF card reader. The reason for using this particular card reader is not because of any brand favoritism; rather we found it slightly faster than our older SanDisk card reader. The fact that is also much easier to find room for it in our camera bag is also a nice bonus.
ATTO Disk Benchmark
Lexar Pro 1066x (CF) 23
Lexar Pro 1066x (CF) 24
AS-SSD
Lexar Pro 1066x (CF) 25
Lexar Pro 1066x (CF) 26
Crystal DiskMark
Lexar Pro 1066x (CF) 27
Lexar Pro 1066x (CF) 28
Just by looking quickly at the above charts it is obvious that Micron’s Lexar division spent significant time and effort in improving this – pardon the pun – Crucial area. While we fully expected the read to be greatly improved, the drastic improvement in write speed is what really, really captured our attention.
To be completely honest this amazing performance increase is what the 800X series never could offer over the 600X. When you take into consideration both the 800x and 600X have a minimum write performance of only 20MB/s and the 1066X has a minimum guarantee of 65MB/s (via VPG standard testing & certification) the new Lexar 1066X is the largest leap in performance CompactFlash has ever seen. Maybe going from PIO to UDMA comes close, but this new series is exactly what CF needed in order to stay relevant to professionals for another generation or two.
Page 7 of 10
Previous 12345678910 Next
Tags: 1066xcompact flashdslrlexarlexar pro 1066x review
The Witcher 3
The Witcher 3
