Lexar 3400x Cfast 2.0
Lexar Professional 3500x 256GB CFast 2.0 Card, Up to 525MB/s Read, for Cinematographer,...
Lexar Professional 3500x 256GB CFast 2.0 Card, Up to 525MB/s Read, for Cinematographer, Filmmaker, Content Creator (LC256CRBNA3500)
Lexar 512GB Professional 3500x CFast 2.0 Memory Card for 4K Video Cameras, Up to 525MB/s Read, Up...
Lexar 512GB Professional 3500x CFast 2.0 Memory Card for 4K Video Cameras, Up to 525MB/s Read, Up to 445MB/s Write Speed
$639.00
2 new from $625.00
as of September 10, 2026 5:32 pm
Lexar 64GB Professional 3500x CFast 2.0 Memory Card for 4K Video Cameras, Up to 525MB/s Read, Up...
Lexar 64GB Professional 3500x CFast 2.0 Memory Card for 4K Video Cameras, Up to 525MB/s Read, Up to 445MB/s Write Speed
5. Lexar Cfast 2.0 – Testing Methodology
  • 1. Lexar Cfast 2.0 – Introduction
  • 2. Lexar Cfast 2.0 – What is CFAST 2.0 and why should you care
  • 3. Lexar Cfast 2.0 – Closer Look at the Lexar 3400X
  • 4. Lexar Cfast 2.0 – Image Rescue 5
  • 5. Lexar Cfast 2.0 – Testing Methodology
  • 6. Lexar Cfast 2.0 – Score Card, Performance Summary & TL;DR
  • 7. Lexar Cfast 2.0 – Closing Statement
Testing external storage designed for use in cameras is not like testing solid state drives, or even compact storage devices like ‘thumb drives’. These devices have very unique standards and have been optimized for highly specialized roles. For this reason we have chosen to do a combination of synthetic and real world tests that will show the intended customer base what the real strengths and weaknesses of a product line are.
To this end we have chosen ATTO, AS-SSD, and Crystal DiskMark for our synthetic test suites. However, we have opted to not include any deep queue depth testing. Instead only the sequential, medium size, and single queue small file size tests are run. ATTO’s full range of file sizes will be included but this only so that consumers can see the performance curves a given storage device offers. Furthermore we will be significantly discounting any results under the 8K mark in ATTO.
For real world we have opted for our usual real world transfer test. This is a two part test. The first consist of timing how long a single 30GB (30 Billion bytes) raw file takes to copy to, and then from the devices. The second consists of timing how long it takes to copy to and then from 15GB (15 Billion bytes) worth of small files (from 100kb to 200MB) with a total 36,000 files in 1200 subfolders. For the card reader we have opted for Lexar’s WorkFlow USB 3.0 series. This series offers great performance, reasonable prices, and is specialized for a specific interface. IE each format has its own WorkFlow model that has been tuned for that particular storage type.
In between each test ran the storage device is wiped and ensured to be in a virgin state via manual TRIM’ing the device using AIS’s FreeSpaceCleaner.
Main Test System
Processor: Intel i7 5930K
Memory: 16GB Corsair Vengeance LPX DDR4-2666
Motherboard: Asus Sabertooth X99
Cooling: Noctua U12S
Power Supply: Corsair AX860i
Monitor: Dell U2714H
OS: Windows 7 Ultimate x64 SP1
Card Reader: Lexar USB 3.0 WorkFlow CR1
testbed
Lexar Cfast 2.0 – Synthetic Test Results
For synthetic tests we have used a brand new Lexar WorkFlow USB 3.0 CFast card reader. The reason for using this particular card reader is not because of any brand favoritism; rather we found it to be one of the best – and one of the few – CFast 2.0 card readers available today.
Before we begin, we do however have to explain one set of numbers: the sequential read. Put simply this card is so fast that the USB 3.0 reader simply can’t keep up. We did retest it using a micro-SATA cable adapter and it cruised along at its rated speed of 510Mb/s, but this radical change in interfaces would not have been fair to the other cards in the chart (as they had to use the USB protocol which does introduce a lot of overhead). We feel this is fair as a Lexar reader was used. As such 380Mb/s is about the most you will see via USB 3.0 – one Lexar equipment. To be honest that is fast no matter how you look at it, but if you want all the performance a ten dollar cable adapter is all that is needed.
ATTO Disk Benchmark
Lexar 3400x Cfast 2.0 20
Lexar 3400x Cfast 2.0 21
AS-SSD
Lexar 3400x Cfast 2.0 22
Lexar 3400x Cfast 2.0 23
Crystal DiskMark
Lexar 3400x Cfast 2.0 24
Lexar 3400x Cfast 2.0 25
As you can see the CFast 2.0 card simply dominates the competition and shows precisely how much performance professionals and enthusiasts will have access to once camera manufactures catch up.
Page 5 of 7
Previous 1234567 Next
Wolfenstein The New Order
