in Reviews, Ram
HyperX Fury RGB 128GB 2666MHz DDR4 CL16 DIMM (Kit of 4) HX426C16FB3AK4/128
HyperX Fury Black 16GB 2666MHz DDR4 CL16 DIMM Single Stick HX426C16FB4/16
Kingston Technology HyperX Impact 16GB 2666MHz DDR4 CL15 260-Pin SODIMM Laptop Memory...
Kingston Technology HyperX Impact 16GB 2666MHz DDR4 CL15 260-Pin SODIMM Laptop Memory (HX426S15IB2/16)
5. Kingston HyperX Fury DDR4-2666 32GB Kit – Load Time Tests
  • 1. Kingston HyperX Fury DDR4-2666 32GB Kit – Introduction
  • 2. Kingston HyperX Fury DDR4-2666 32GB Kit – Specifications and Features
  • 3. Kingston HyperX Fury DDR4-2666 32GB Kit – Testing Methodology
  • 4. Kingston HyperX Fury DDR4-2666 32GB Kit – Benchmarking
  • 5. Kingston HyperX Fury DDR4-2666 32GB Kit – Load Time Tests
  • 6. Kingston HyperX Fury DDR4-2666 32GB Kit – GTA V FPS Test
  • 7. Kingston HyperX Fury DDR4-2666 32GB Kit – Score Card and Summary
  • 8. Kingston HyperX Fury DDR4-2666 32GB Kit – Closing Statement
ADOBE CS6 LOAD TIME
Photoshop is a notoriously slow loading program under the best of circumstances, and while the latest version is actually pretty decent, when you add in a bunch of extra brushes and the such you get a really great torture test which can bring even the best of the best to their knees. Let’s see how our review unit faired in the Adobe crucible!
Kingston HyperX Fury DDR4-2666 32GB Kit 17
VMWare Load Time Performance
VMWare is a powerful application which allows users the ability to run a virtualized Operating System from inside their main OS. This program is not only processor and RAM intensive but puts significant load on the storage subsystem with deep, heavy read/write IO requests to the drive. To help give you a general idea on the performance improvements from running a RAM Drive we have timed the time it takes to load Microsoft Window’s XP SP3 from inside VMWare.
Kingston HyperX Fury DDR4-2666 32GB Kit 18Easy to setup and use? Check. Ability to go faster than a scaled cat? Check. This kit really is darn impressive in how versatile it really is. Brilliant stuff!
Borderlands 2 Load time
For Borderlands 2 we have recorded the time it takes to fast travel from Sanctuary map to Oasis. Oasis is the beginning of the Captain Scarlett and Her Pirate’s Booty DLC. This was chosen as it not only is a special level not included in the original Borderlands 2 game, but also contains additional data which should slow the load of this special map even further.
Kingston HyperX Fury DDR4-2666 32GB Kit 19
Saints Row 3 Load time
Kingston HyperX Fury DDR4-2666 32GB Kit 20
Page 5 of 8
X99A GAMING PRO CARBON with front USB 3.1 Type-C and U.2 is here!
MSI GE76 Raider 12U Review
USB 3.0 cables go optic
April 22, 2014
