in Reviews, Ram
12. SolidWorks & WinRAR
  • 3. DDR5 Primer P.1
  • 4. DDR5 Primer P.2
  • 5. DDR5 Primer P.3
  • 6. Closer Look P.1
  • 8. Adobe Performance
  • 9. Blender & Cinebench
  • 10. DaVinci & Handbrake
  • 11. POV-Ray & OpenSCAD
  • 12. SolidWorks & WinRAR
SolidWorks Performance Test (CPU only)
SolidWorks is a solid modeling computer-aided design (CAD) and computer-aided engineering (CAE) application published by Dassault Systèmes. While not as well known as some other professional CAD programs it is a powerful CAD program that can bring even the most powerful of systems to their knees. To help ensure professionals actually have enough horsepower it comes with a simple, yet decent, benchmark. Consisting of many parts it tests the entire system. However, only the CPU portion of the results are recorded.
Intel:
Crucial Pro DDR5-5600 128GB Review 41
AMD:
Crucial Pro DDR5-5600 128GB Review 42
winRAR Benchmark
Intel:
Crucial Pro DDR5-5600 128GB Review 43
AMD:
Crucial Pro DDR5-5600 128GB Review 44
Page 12 of 15
