Crucial P510 Review
Power to the People!
Crucial P510 Review
Crucial P510 Review 6
Even though Micron’s CMOS Under the Array (CuA) Replacement Gate based NAND has been around for many years now, not everyone actually ‘gets’ what makes this type of NAND different than the other NAND manufacturers’ options… and why it was so revolutionary when first released. As such, we feel that it is still necessary to include a primer on what this NAND is. The easiest way to imagine what Micron has done to create their ‘Replacement Gate’ NAND is to imagine the melding of typical Charge Trap design with earlier Micron CuA NAND logic layout. Then imagine it bigger, stronger, and better than other previous Micron NAND designs. Simply put, it is a new spin on Charge Trap NAND theory and design… and not an entirely new approach to NAND design.
For those that are new(er) to SSD technology and want to know exactly what ‘Replacement Gate Technology’ is… a bit more theory and information is needed. The foundation of all Not-AND (aka ‘NAND’) Solid State storage is a tiny little electrical gate, and a tiny little electrical ‘battery’ cell called a transistor. To change the stored data bit from a 0 to 1, or vice versa, the controller tells the gate to either let the charge ‘out’ (aka ‘discharge the cell’) or store some in the cell. This is called a program operation as it is setting the charge state of cell or ‘programming’ it.
Crucial P510 Review 7
To read the NAND cell, the controller simply pushes a tiny trickle of power across the gate and reads that cell’s charge. For example, in SLC or single-level cell NAND, the cell has two states: full and empty. Ironically, since the controller is reading a difference in voltage across the cell, the default ‘empty’ state is usually considered 1 and not a 0. So, an ‘empty’ or discharged state is the same as storing a 1 in that cell, and fully charged is a 0 bit. For old timers, this is why in AS Cleaner or ‘Tony Trim’ type programs (before TRIM was a sure thing), you had to use the ‘FF’ write option… as ‘FF’ is the same as all ones being written to the cells.
Since a NAND transistor can hold its charge even when the system is powered off, NAND storage is considered ‘non-volatile storage’. However, just like ‘bit rot’ on a Hard Disk Drive, this state is not permanent. Instead, and just like the battery in your turned-off phone, if left long enough, the power in those tiny transistors will leak out… and turn a 0 into a 1. This is a bad thing from a long-term storage point of view.
With SLC NAND, a cell that is left alone will not lose all that much voltage and is fairly stable for months between power-on states. However, as each NAND cell can only store 1 bit, it is rather expensive to create, say, a 1TB Solid State Drive, and scaling up beyond 1TB requires a lot of NAND chips. Even layering NAND cells on top of NAND cells on top of NAND cells, the resulting footprint would be rather large. This combination is why Multi-Level Cell NAND was created and doubling a NAND cell’s storage capacity from 1 bit to 2 bits. It did this by adding more voltage resistance points between ‘full’ and ‘empty’. So instead of two states, there were now four states: 0, 0.25, 0.5, 0.75, and 1. This certainly increased storage density, and decreased the cost of manufacture to hit a given storage capacity, but at the same time made the self-discharging of NAND a greater issue, as lot less of a voltage change can indeed impact two bits of data. This is why MLC is not as stable as SLC and must be refreshed/rewritten more often (aka ‘internal housecleaning’).
As time went by MLC was further supplanted by TLC (Tri-Level Cell) NAND, which can store three bits of data per cell. In TLC NAND, there are not two, not four, but eight voltage states (for comparison’s sake to hit 4 bits per cell, QLC NAND requires sixteen voltage points). This, in turn, increases the necessary precision in properly writing and reading a given state of a NAND cell. It also significantly decreases how long a TLC NAND cell will hold this more precise voltage state. This increased precision plays a large role in why TLC NAND is ‘slower’ at write operations than MLC (which is in turn slower than SLC)… and why QLC (and its sixteen voltage points) is slower still.
Crucial P510 Review 8
In the original NAND design, how a NAND transistor worked was via a ‘floating’ gate (FG for short). With an FG transistor, the gate itself is the conductor of electricity. Thus, in order to change a NAND cell’s state, electricity must be pushed through the gate itself. Over time,e this sudden shock of current running through the floating gate causes minuscule fractures in the crystal lattice that make up its foundation.
The size of these fractures and their likelihood of occurrence are directly tied to how hot the transistor is; however, even a ‘cold’ NAND transistor will do slight damage to its gate every time a charge state change is required. On their own, a single fracture will not cause voltage-related issues, but over time, the cumulative effect does create a significant problem. When this happens, the result is a gate that is incapable of keeping voltage levels inside the transistor stable. This is what a ‘dead’ NAND cell really is – a NAND cell that can no longer be trusted to hold a precise charge.
Worse still, with every reduction in fabrication node size, the cell itself not only becomes smaller, but the gate itself also becomes smaller. A smaller gate not only has less tolerance for heat but also means fewer defects are required before the gate fails. Also, the more precise the voltage requirements, the faster cumulative defects become an issue.
In layman’s terms, a floating gate literally ‘eats itself’ every time it is called upon to change the charge state of its transistor(s). The smaller the gate, or the more precision required, the faster it finishes its meal… and the faster the cells die. NAND manufacturers are aware of this issue and include free NAND cells to replace ‘dead’ cells. They are also fully aware that this is only a band-aid solution,n as eventually there will be no more replacement cells left.
Crucial P510 Review 9
Controller and storage companies are also aware of this issue and include even more ‘replacement cells’ (aka ‘over-provisioning’ and why your 256GB drive may be seen as a 240GB drive) but also use slower / gentler write algorithms to reduce this damage (typically using 8 voltage steps or more). In simplistic terms, this means they write to the NAND using less voltage but over a longer period of time. This does reduce cell damage, but at the cost of write performance. To overcome this side effect, the controller will pretend a given chunk of TLC NAND is SLC NAND and only store two charge states instead of eight (or 16 in the case of QLC) per cell. This allows those cells to continue being used long after the amount of damage to the gate would result in random bit changes if eight (or more) states were needed (some estimate the difference at 40K program erasure cycles vs. 5K p/e cycles). This pseudo-SLC is then used for real-time writes as a buffer and is called different things by different manufacturers. For example, Crucial calls it “Dynamic Write Acceleration”.
Sadly, including more backup NAND cells and/or lowering the voltage applied does nothing for charge coupling. This rare event happens when the fracture in the lattice is close enough to a neighboring NAND cell that the electrons can jump from one cell to another, creating a quasi-bridge between the cells. This, in turn, can randomly impact multiple cells’ worth of data and do so silently, with the controller only knowing about it when it checks the state of the cells vs. what they were supposed to be. To visualize this, imagine sorting your spare change into cups that are touching one another… and a quarter bounces off the lip and ends up in the dime cup. Both cups’ total amounts will be off, and you will not know they are off until you count both cups.
Crucial P510 Review 10
These are all well-known issues. Issues that have been known for decades. While Samsung and Toshiba opted to change the very foundation of how their NAND transistors work… Micron and Intel opted to increase the size and rearrange their cell layout to help reduce them to manageable levels. Put another way, they decided to kick the can down the road. The upside is the CMOS under Array (CuA) design was created. One where the interconnects are much like ‘elevators’ in an apartment building (at the ends of the ‘hallways’) and the logic hardware is under the NAND transistor array (think ‘basement’ in an apartment building). This layout helps (to some extent) alleviate heat buildup by moving the potential hotter running interconnects closer to the edges of the NAND block.
The downside to typical CuA NAND is twofold. Firstly, it was still FG tech-based. Secondly, CuA is not exactly the most efficient layout. It does tend to bottleneck slightly faster than some of the competition… and the deeper the NAND layer depth, the more it is likely to occur under sustained, extended loads. To help minimize this last issue, Micron has continually improved the speed at which the NAND itself operates. For the latest generation, dubbed 9th but only 4th CuA RG based, they have opted for a rather fast ONFI “NV-DDR4 IO” rev 5.1 bus, which can handle 3600 MegaTransfers per second. Thus CuA “Replacement Gate” 4.0 has ‘hallways’ and ‘elevators’ which are 50 percent wider than the previous gen 3’s 2400MT/s… which was 50 percent faster than 2’s 1600MT/s, which in turn was 50 percent faster than the previous CuA NAND’s 1200MT/s bus.
Interestingly enough, Micron has not increased the number of ‘hallways’ nor the actual layout from the previous generation’s 6 planes x 2 (blocks) per die configuration that proved highly successful. They also have not increased the number of cells per sub-block; instead, what they have done is add on to the total number of layers each die has, going from 232 to 276 layers. This allows the ‘9G’ era to be fast. Very fast. Very fast at block erasures and even overall die write speeds. Which are the two biggest bottlenecks in modern NAND. Especially when either all the ‘free’ NAND blocks needed to be cleaned before use, or when the pseudoSLC write cache buffer is exhausted. Two scenarios that absolutely tank overall real-world performance. Thus, this increase in low-level performance not only boosts IOPS and sequential performance, but allows this NAND the luxury of being capable of working superlatively well even when in 4-channel controller-based SSDs. Something every NAND manufacturer has struggled with since said controller’s mainstream acceptance.
Will that still be the case in the future when PCIe 6.0 doubles the bus and thus doubles the pressure being placed on the NAND? No one knows. What Micron is betting on is that ONFI will continue to increase the spec’s maximum allowable frequency faster than their CuA’s low-level bottlenecking issue transforms from a theoretical into a real-world issue. In the meantime, this new Replacement Gate “G9” NAND tech is relying upon an incredibly fast bus (by today’s standards) that is more than up to the demands placed upon it.
Crucial P510 Review 11
This is where the other half of the changes that come along with Replacement Gate technology come into play… as Micron literally replaced their NAND cells’ gate technology. Instead of the Float Gate that was used before, and all the issues outlined above that go along with it, Micron has finally admitted that the Charge Trap (CT) design is superior. Since Intel is essentially out of the consumer marketplace, this makes the Float Gate design a dead tree branch tech. One that only CompSci university students will learn about in their history books.
In CT-based NAND, the gate is not a conductor, instead, it is the insulator. So instead of being responsible for getting power into the gate, it is responsible for keeping it there. This means that during write or erase operations, less stress is placed on the gate itself. Since the method of charging/discharging is different, the operation can not only be faster (typically about half the time vs FG) but gentler (typically 6 voltage states). The end result is that those deadly fractures are less likely to occur, and when they do happen, they are usually measured at the electron level. Since they are smaller, they can only drain off the electrons that are ‘touching’ the fracture. Leaving the rest of the electrons in the cell to control the voltage adequately enough that the controller can still accurately tell what the cell state is.
Crucial P510 Review 12
While yes, eventually fractures in the gate’s lattice matrix will multiply to the point that they also cause the cell to be marked as ‘dead’, the likelihood and severity mean a CT-based NAND transistor will last noticeably longer than a float trap design. Equally important, this in turn not only increases longevity of the NAND cell but also allows for faster – and yet ironically enough still gentler- programming cycles to be implemented on the NAND. Which, in turn, increases sustained write performance. Charge Trap gates also gain longevity and performance from the switch from planar (aka 2D) NAND designs to 3D designs. Arguably, CT NAND gains even more durability as they do not ‘eat themselves’ nearly as fast as FG NAND, so the increased mass means the NAND cells last even longer. When paired with pseudo-SLC algorithms, the result is higher sustained performance, increased durability, and generally a better end-user experience.
Crucial P510 Review 13
Where Micron was starting with both a blank slate and over a decade worth of real-world data provided to them by their competition their design team has been able to focus in fixing a weakness that existing CT designs have – their layout. In classical Charge Trap NAND, each cell is laid out just as it would be in FG NAND design, with each cell being a separate and distinct ‘apartment’… with one ‘family’ (or 1/2/3/4 bits of storage depending on NAND type) per ‘apartment’. While this is indeed an improvement in both the durability and performance characteristics, charge coupling is still an issue, performance is still not optimal, and neither is data density.
Crucial P510 Review 14
To understand these issues, imagine the typical high-end condo building. While all the condos on a given floor share the hallway, each condo has its own door and rather thick “firewalls” separating one condo from another. In Replacement Gate technology… Micron has clustered cells into groups. With a nonconductive layer of silicon nitride surrounding the insulator gates. This not only allows Micron to consistently increase performance (100% write / 75% read RG 3.0 improvement over RG 2.0 which in turn was 33-35% faster than their previous non-RG CuA NAND) and scale up the number of layers per deck each generation of Replacement Gate NAND offers (232 vs 176), but also reduce the footprint each TB of NAND requires on a drive’s PCB. For this generation, it is a 28% reduction in the room required to hit a given drive’s specified capacity. It also promises to be even more resilient to charge-coupling issues, further making it even more reliable when compared to standard CT NAND designs.
Without going into white paper levels of detail, all the above is the simplified basics on what makes Replacement Gate Technology ‘tick’ and why Micron has indeed not only achieved parity but arguably surpassed the competition with the release of their next generation 276 Layer CuA RG NAND.
Page 3 of 15
Intel Expands GPU and AI Portfolio
