Crucial P510 Review
Power to the People!
Crucial P510 Review
System Boot Time
When it comes to hard drive performance, there is one area that even the most oblivious user notices: how long it takes to load the Operating System. While all the other tests were run with a Windows 7 operating system, this particular test uses another older test bed’s “day to day” OS (copied over to our new testbed), which has accumulated a lot of crud over the months from installs and removals. We chose the Anti-Virus splash screen as our finish line as it is the last program to be loaded on startup.
Crucial P510 Review 31
Real World Data Transfers
Testing will include transferring to and from the devices, using MS RichCopy, and logging the performance of the drive. Here is what we found.
Crucial P510 Review 32
Crucial P510 Review 33
Page 10 of 15
Intel Expands GPU and AI Portfolio
