Crucial P310 2280 Edition 2TB Review
Same great taste, now more filling (of the M.2 slot)
Crucial P310 2TB 2280 PCIe Gen4 3D NAND NVMe M.2 SSD – Up to 7,100 MB/s – Shift up to Gen4, with...
Crucial P310 2TB 2280 PCIe Gen4 3D NAND NVMe M.2 SSD – Up to 7,100 MB/s – Shift up to Gen4, with Acronis Offer, Internal Solid State Drive (PC) – CT2000P310SSD801
Crucial P310 2280 Edition 2TB Review 7
Crucial P310 2280 Edition 2TB Review 8
As time went by MLC was further supplanted by TLC (Tri-Level Cell) NAND which can store three bits of data per cell. In TLC NAND there are not two, not four, but eight voltage states (for comparison’s sake to hit 4 bits per cell, QLC NAND requires sixteen voltage points). This in turn increases the necessary precision in properly writing and reading a given state of a NAND cell. It also significantly decreases how long a TLC NAND cell will hold this more precise voltage state. This increased precision plays a large role in why TLC NAND is ‘slower’ at write operations than MLC (which is in turn slower than SLC)… and why QLC (and its sixteen votlage points) is slower still.
Crucial P310 2280 Edition 2TB Review 9
Crucial P310 2280 Edition 2TB Review 10
Crucial P310 2280 Edition 2TB Review 11
Crucial P310 2280 Edition 2TB Review 12
Crucial P310 2280 Edition 2TB Review 13
Crucial P310 2280 Edition 2TB Review 14
Crucial P310 2280 Edition 2TB Review 15
Page 3 of 15
Tags: 2280 form-factoraffordable SSD PCIe 4.0budget-friendly SSDCrucial P310QLC NANDSSDSSD performancestorage upgrade
AData SC740 1TB Review
May 9, 2014
