Cooler Master MA624 Stealth Review
CoolerMaster MasterAir MA624 Stealth CPU Air Cooler, 6 Heat Pipes, Nickel Plated, Dual Aluminum...
CoolerMaster MasterAir MA624 Stealth CPU Air Cooler, 6 Heat Pipes, Nickel Plated, Dual Aluminum Fins, Push-Pull SickleFlow 140mm Fans for AMD Ryzen AM4, Intel LGA1700*/1200/1151 (MAM-D6PS-314PK-R1)
Cooler Master MasterAir MA624 Stealth CPU Air Cooler, Dual Tower Heatsink, Push-Pull SickleFlow...
Cooler Master MasterAir MA624 Stealth CPU Air Cooler, Dual Tower Heatsink, Push-Pull SickleFlow 140 V2 Fans, 6 Heat Pipe Array, Easy Installation, Matte Black Finish - Universal Socket Compatibility
Cooler Master AMD Wraith Ripper ThreadRipper TR4 High Performance CPU Air Cooler, ARGB...
Cooler Master AMD Wraith Ripper ThreadRipper TR4 High Performance CPU Air Cooler, ARGB Threadripper logo’s display, 7 Heat Pipes, Dual Tower Heatsink, Wraith Armor Air-Guide
5. Testing Methodology
  • 1. Gorgeous but Quirky Cooling
  • 4. Installation & Issues
While there are many, many ways of properly and efficiently testing CPU cooling solutions not every method will offer useful information for all potential buyers. Some consumers care more about noise than shear performance (aka ‘Silent PC’ enthusiasts). Others only care about performance and do not mind in the least if the cooler is as loud as a jet plane. Others still want to know how flexible a cooler is and how effective it will be at moderate – not silent – noise levels. Most though fall somewhere in the middle and want a good all-round design. Further complicating things is results on consumer Intel systems do not necessarily translate to bigger “HEDT” CPU based testbeds (and vice versa)… as the CPU is a different size and will come in direct contact with more/less of the CPU cooling solution’s heatsink.
This different approach starts with testing on two testbeds and not just one. The first is an Intel 11th generation Core i9-11900K CPU. This CPU’s thermal characteristics make it a good representation of “worst case scenario’ for what most users will experience. For power users who like HEDT/workstation/etcs systems we have opted for a Core i9 10980XE based system. Both are tested at stock and a moderately stressful overlock.
Further helping to give as clear a picture of a given cooler’s real-world performance, we also will be testing a test sample with stock number of fans (i.e. whatever number is included in the box), and (when possible) the maximum number of fans that can be mounted. For most air-based coolers this means one fan for stock, and two to three for maximum results; whereas with water-based stock it could be one or two for stock, or three to six for maximum.
Consumer Testbed:
Processor: Intel Core i9-10900K
Motherboard: ASUS ROG Maximus XIII Hero Z590
Cooling: Various
Power Supply: Corsair AX860i
Monitor: Dell U2714H
OS: Windows 10 Professional
HEDT Testbed:
Processor: Intel Core i9-10980XE
Motherboard: ASUS TUF MARK X299
Cooling: Various
Page 5 of 9
Tags: air coolingCooler masterCooler Master MA624 Stealthcpu cooling
Intel Launches Alder Lake 12th Gen Core Processors
