Cooler Master, a leading provider of PC components and peripherals, has announced the release of its latest MasterFan Halo² series. The new fan series is a stronger update of the previous MasterFan Halo series, which was well-received by PC enthusiasts around the world.
The Cooler Master MasterFan Halo² series features the signature Dual Loop ARGB LED lighting of the original Halo fan, but with improved cooling capabilities and enhanced lighting vibrancy. The fan series comes with a 10% increase in fan blade size that allows for more airflow and stronger cooling performance. Furthermore, the Hybrid Frame Design and updated Fan Control IC minimize fan noise while providing efficient cooling.
The MasterFan Halo² series comes in two sizes, 120mm and 140mm, with each size available in a regular and a white edition. The 120mm fan has a maximum speed of 2050RPM, while the 140mm fan has the same maximum speed. Both sizes have the same features, including larger fan blades, Hybrid Frame Design, more vibrant ARGB lighting, and an updated Fan Control IC.
According to Cooler Master, the MasterFan Halo² series is designed to light up PC builds around the globe. The series is suitable for both novice and advanced users and can be used as case fans, radiator fans, or in a push-pull configuration.
The product pages for the MasterFan Halo² series are now available on the Cooler Master website, where customers can find more information about the new fan series. Customers can also download the product sheets and press release from the website.
The MasterFan Halo² series is expected to be available for purchase in the coming weeks. With the improved cooling and lighting capabilities, the series is set to be a hit among PC enthusiasts worldwide.
