Home Cooling
Cooler Master Hyper 212 Black Edition Review
The (CM) Empire Strikes Back
in Cooling, Reviews
Cooler Master Hyper 212 Black CPU Air Cooler, Silencio FP120 PWM Fan, Anodized Gun-Metal Brushed...
Cooler Master Hyper 212 Black CPU Air Cooler, Silencio FP120 PWM Fan, Anodized Gun-Metal Brushed Nickel Fins, 4 Copper Heat Pipes for AMD Ryzen AM4, Intel LGA1700/1200/1151 (RR-212S-20PK-R2)
Cooler Master Hyper 212 RGB Black Edition CPU Air Cooler, SF120R RGB Fan, 4 CD 2.0 Heatpipes,...
Cooler Master Hyper 212 RGB Black Edition CPU Air Cooler, SF120R RGB Fan, 4 CD 2.0 Heatpipes, Anodized Gun-Metal Black, Brushed Nickel Fins, RGB Lighting for AMD Ryzen/Intel LGA1151
5. Testing Methodology
  • 4. Installation and Issues
This different approach starts with testing on two testbeds and not just one. The first is an Intel 13th generation Core i9-13900K CPU. This CPU’s thermal characteristics make it a good representation of for what most upper-mainstream users will experience. For AMD fans, we have an older Zen 3 Ryzen 9 5950X processor. A processor that just does not like to run cool.
Intel Testbed:
Memory: Crucial Pro DDR5-5600
Cooling: Various
Power Supply: Corsair AX860i
Monitor: Dell U2714H
OS: Windows 11 Professional
AMD Testbed:
Processor: AMD Ryzen 9 5950X
Cooling: Various
Page 5 of 9
Tags: air coolerBlack Editioncomputer hardwareCooler masterCooler Master Hyper 212 Black EditionCooling SolutionsCPU CoolerGamingHyper 212OverclockingPC ComponentsPC CoolingTechnology
