AData SC740 1TB Review
A Hidden Gem Packed With Performance
ADATA SC740 External Solid State Drive 1000GB, USB 3.2 Gen2 USB-C External Portable SSD - up to...
ADATA SC740 External Solid State Drive 1000GB, USB 3.2 Gen2 USB-C External Portable SSD - up to 1050 MB/s
5. Synthetic Performance
  • 7. Score Card & Summary
ATTO Disk Benchmark
The ATTO disk benchmark tests the drive’s read and write speeds using gradually larger size files. For these tests, the ATTO program was set to run from its smallest to largest value (.5KB to 8192KB) and the total length was set to 256MB. The test program then spits out an extrapolated performance figure in megabytes per second.
AData SC740 1TB Review 22
AData SC740 1TB Review 23
AS-SSD
AData SC740 1TB Review 24
AData SC740 1TB Review 25
Crystal DiskMark
AData SC740 1TB Review 26
AData SC740 1TB Review 27
Page 5 of 8
Tags: 1TB SSDADataBest SSD Dealsbudget SSDData ProtectionDurable SSDExternal SSDFlash DriveGen 2x2High-Speed StoragePerformance TestingSC740storage upgradeTech ReviewUSB 3.2
